Record to COLLADA: Failed to initialize the add-in. Your version of RobotStudio may not be supported
Hi. I'm getting this message everytime I run RS: "Record to COLLADA: Failed to initialize the add-in. Your version of RobotStudio may not be supported". Does anyone has the same message? How did you fixed it? I use the latest version of RS. Thank you for your time. Pedro Severin
  • Hi Pedro, here is an updated version of the add-in. Regards, Johannes
    Johannes Weiman
    RobotStudio Team, ABB Robotics
  • I havr also  downloaded recordcolladaanimationadd-inforrobotstudio5.60.zip and copied the dll file in:
    C:\Program Files (x86)\ABB Industrial IT\Robotics IT\RobotStudio 6.02\Bin\Addins
    "A possible reason is it was downloaded from Internet "¿?
    Do you wish RS attemts to unlock the file? I say Yes, and later RS says,
    Impossible to unlock
    I've also tried with 6.02 add-in.. at first it says "You have to restart RobotStudio" so I did; but  when I inicialize RS, now it says in the Output WIndow:
    Record to COLLADA:Failed to initialize the add in. Your version of RobotStudio may not be supported.
    Bottom line:
    RecordtoCollada 6.02 + RS 6.02 = Your version of RobotStudio may not be supported ¿?
    RecordtoCollada 5.6 + RS 6.02 = Impossible to unlock. "A possible reason is it was downloaded from Internet "¿?
    Pedro Severin and I cannot fix it yet.
    @JWeiman Does the 6.02 add in works in your RobotStudio? Which version is? Does your pc is x64 or x86?
    Any help you can give me I would be very grateful.
    Best Regards,
    Pablo Liberona
