Write to an FTP server
Is it possible to write a file from the robot to a ftp server. And how?
  • soup
    soup ✭✭✭
    Yes -- writing to a FTP server uses the same commands as writing locally -- Open, Write, Close -- but the FTP server location is first setup in the SIO config file (Configuration > Communication in RobotStudio).
  • Okay. found what I need basically, but something is still wrong. Can I use it in an virtual controller?
  • soup
    soup ✭✭✭
    I can't get a known good FTP configuration to work on a virtual controller.
