Unabled to add new task
I'm trying to add a new task, but the button is disabled. My station has 623-1 Multitasking installed.
I'm using RobotStudio 6.01
Can anyone help me?
  • Is it a real or a virtual system and what RobotWare are you running?
    Per Svensson
    Consat Engineering
  • If you added Multitasking after the system was created did you I start the system (make sure you save any RAPID programs first)?
  • I have found the problem. :smile:  I have set up the station a bit wrong.
