How do I set up multimove in Robotstudio?
Yandisa
I want to control three robots which will work independent of each other using a single controller in robotstudio. Can anyone please help me with suggestions of how I can do that?
The easiest way is to create a empty solution, add the three robots (and position them in the correct places) from the ABB library then from the robot system button select from layout - follow the prompts taking the appropriate RobotWare options when asked.
Regards
Graeme
1 -
Thank you Graeme. That helped!
Regards
Yandisa0
