Movement functionality of the Robot axes with hand and with flexpendant joystick.
Tekabi
Hello Dear all,
I need to know that is it possible to move the Robot axes with hand, in addition to flexpendant joystick, to define a motion for the Robot?
Best regards
Tekabi
Best regards
Tekabi
You need the RobotWare option Force Control combined with a force sensor mounted on the robot to be able to use lead through programing.
Regards
Graeme
Hi Dear Graemepaulin,
Thanks for your reply.
I have another questions from you:
1) what do you mean a force sensor? what's that at all? and what applications does it have?
2) The RobotWare option Force Control, is a setting that have to be set by flexpendant, or not? ( Please explain more, if possible )
Best regards
Tekabi
This YouTube video show the principal https://www.youtube.com/watch?v=acJ3WDnoDCM
Things have advanced since this video:
- a programing handle that means you do not need to use the Teach Pendant.
- you can teach the path as a movement (not discrete points as shown).
Regards
Graeme
Thanks again for your best reply.
I have seen this video, but i don't know that haw can i enable this function of the Robot? / Or, what Proceedings is needed in order to do this? and also what settings is needed in teach pendant?Best regards
Tekabi
You need additional hardware (force sensor), and RobotWare options before you can use this functionality.
Contact your local ABB and they will be able to advise exactly what is required for your system.
Regards
Graeme
- 304 PowerPacs
- 354 IRC5
- 850 RAPID Programming
- 26 AppStudio
