Issue with configuration of IRB1600
Luxrobotic
Luxrobotic ✭✭
edited November 2015 in RobotStudio
Good morning everybody,
I have a station with 2 IRB 1600. When I try to setup the configurations, for some paths, I can't find the correct config in the list.
For this position, I need to use [0,0,0,2], it's not available in the list (Pict : Configs_2).
To have the right config, I need to make a manipulation to be able to force the auto-config.
I place an instruction from another path (With config ok) in the begining of my path (Pict : Configs_4), and make an auto-config (Pict : Configs_5).
But, when I look in the Rapid code in the VC, the config which has been attribuated after the auto-config is [0,0,0,2], but I still can't find it in the list.
I hope you can understand my problem, because it's a little bit hard to explain.
Thanks.
Raymond
Regards
Cornet Raymond
Manager
+352 621 354 570
raymond.cornet@luxrobotic.com
http://www.luxrobotic.com
HP ZBook Fury 16 G11
  • What if you check include turns?
    Per Svensson
    Consat Engineering
  • I am in the same situation...
    When I "auto-configure" a path, the config from the RAPID code does not appear in the list.
  • Hi,
    I don't find the same config in the list, even if I include turns.
    Regards
    Cornet Raymond
    Manager
    +352 621 354 570
