RS 3.2 mechanism not fully working
sturner
I have imported a RS 3.2 mechanism of a Schunk Gripper.rlb and found that I can only operate one of its joints, I.E. its L/H finger. both work in RS3.2. Any thoughts?
Can i run an event that executes a macro in RS 5, in order to operate the gripper from the program/FlexPendant's I/O as in RS3.2
I attach the zipped gripper files. 2006-08-01_153727_Gripper.zip
I am opertaing RS 5.07
if you download RS 5.07.01 release it will just work fine.
I've verified the by both importing your gripper in 5.07 and 5.07.010 -
and more..
Unfortunately there is no integrated macro environment editor as VBA in RS 507. An integrated macro editor will come together with RS 508.
- 5.4K RobotStudio
- 384 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 734 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
