Monitor simulation
I am uisng the monitor simulation of RobotStudio 6.00.01 to monitor the different movements of the robot. But the trace is made from axis6 and not from the tool. How can I change it?In the previous version, it works perfectly.
  • Hi,
    The trace should use the TCP of the tool specified in the move instruction. Sounds like your path is programmed with tool0?
    Johannes Weiman
    RobotStudio Team, ABB Robotics
  • Hi,
    No, I check it and all the targets are programmed using the correct tool.
    The problem is that when I move manually the trace is made from the tool0, but when I execute a program, the trace is made from the tool
