How to read fluid flow for hardener and paint seperatly?
I want to read paint and hardener flow seperatly from the IRB5400 2K. Is there a way for this? I am currently using A1FluidAccu and A1FluidMixRatio to calculate both.
thanks and best regards.
  • I use Robview for that.  You can use Signal analyser, create a user screen or use IPS monitor (as shown below), then just look up A1Pump1 & A1Pump2 and get their actual flow rates.
  •      Thank you for your answer. Can i reach these values from Robotstudio so i can log them?
  • I'm not sure you can but you can do so with Signal Analyser in Robview.
