RobotStudio > 6.0 I/O signal
St4rk
Hello, how I set I/O signal in RobotStudio verzion higher than 6 ? There is missing Unit so what I should do ? Thanks.
Nobody ?0
You no longer need a virtual unit to create virtual I/O signals - so just create the signal in the EIO file without reference to a unit or a physical address (just name and type of signal).
Regards
Graeme
Hi there
How to make I/O accessible for smart components?0 -
Per Svensson
Consat Engineering0 -
Hi!
I have the same question. I design a smart component for a 2 parallel fingers gripper and I want that the robot controls the gripper, but I don't know how do it.
Please help me.
Where is the EOI file?
Thanks!!!!0 -
Hi!
I create the Gripper and the I/O signals with a smart component. I you need to setup I/O connections between the gripper and the robot system, but I don't find the I/O of the robot. How could I do this?
I read something about EOI file, what is this?
Thanks!!!0 -
There are some videos about smart components in this thread
https://forums.robotstudio.com/discussion/comment/24058/#Comment_24058
This one is about smartcomponets and how to connect controller IOs to SC IOs
http://websvrnu.his.se/au113g/smartcomp4/smartcomp4.html
/Pavel0
- 304 PowerPacs
- 354 IRC5
- 850 RAPID Programming
- 26 AppStudio
