Track and robot move in opposite direction
Folks,
in base coordination the X axis from the robot is the opposite of the track. if I jog the track towards plus the X value of the robot becomes smaller.
how can I fix this?
Thanks!
Does the robot actually move (when you jog the track), or is it just the value that changes?0
You will need to rotate the base frame of the robot to match the base frame of the track.0
