Solved: Virtual signals in RobotStudio 6.02
ko414du4
How do you create a virtual signal in RobotStudio 6.02? Earlier in RS 15.15 you can create a virtual bus and a virtual unit, and then a virtual signal. But in RS 6.02 there's only "Industrial Network" and the virtual unit/bus is greyed out. Help please..
Many thanks.
Many thanks.
Post edited by ko414du4 on
With RW 6.x you don't need the virtual bus & unit, you just choose <none> for Device when creating the signals.
Regards,
JohannesJohannes Weiman
Thanks JWeiman!0
- 303 PowerPacs
- 353 IRC5
- 849 RAPID Programming
- 24 AppStudio
