Axis limit switches for IRB6640/130-3.2M
Some ABB robots come with axis limit switches. Does anyone know if IRB6640 comes with them or not?  Thank you.
  • Axis limit switches are/were an option you would order them if needed.
    EPS (Electronic Position Switches) is the replacement for physical limit switches now on ABB robots - this allows you to setup the required limits electronically - the hardware being an additional monitoring computer that fits in the IRC5 controller.
