How to set PP to main at Start
Hello all,
I have been searching for a while and I did not find a way to set the PP to main at Start from RAPID code or controller configuration.
I need a way to start always from the begining when the Start button is pressed.
is there any way to do it?
I have seen the system input 'Start at main', but I am not able to use it right now.
I have also seen the programmable button in the FlexPendant, but I need to do it automatically.
Thank you in advance.
Daniel M.
Daniel M.
ExitCycle will do it
Per Svensson
Consat Engineering5
too easy to find it.
thanks0
- 858 RAPID Programming
