Unreachable Path in Simulation
Dear Admin,
I have below configuration before and after simulation in RobotStudio. I wonder why the last circular path (the one from fourth target to fifth target/first target) is not reachable during simulation meanwhile before simulation i already check that all the path and targets are reachable by previously rotate the tools and configure the robot.
Thanks,
haryprabs
  • when you moved your robot from te graphical world did you also select to move the task frame? you get a question when you move the robot in the graphics
    Per Svensson
    Consat Engineering
  • I have selected move task frame but i still get the same problem. One of the error message is 'WObj not connected'.
    Would you mind to check my solution on the attached file.
    Thanks,
    haryprabs
  • You need to make a Pack&Go(can be found in file\share) so that the controller is included
    Per Svensson
    Consat Engineering
  • Dear Per,
    Sorry. Please find attached zip file of my solution Pack&Go.
    Regards,
    haryprabs
  • Thank you very much Per. This works.
    Regards
