Sharing wobjdata in multimove
I have 2 robots with 1 controller (option multimove) and they are sharing the same work area. My idea is for the robot to share the same work object data. How do I do this? Any comments are well appreciated.
  • soup
    soup ✭✭✭
    See "Relative Calibration" in the Multimove or FlexPendant manual.
  • Hi soup,
    Thank you for your response. I have taken a look at "Relative Calibration" and tried it, but I got an error below. Anything that I missed??
    Thanks again.
  • Hi soup,
    Is it possible that the error is because my system option is "604-2 Multimove Independent" as supposed to "604-1 Multimove Coordinated"? Thanks.
  • Hi soup,
    Thank you for your response. I've had a look at it and tried it but it came up with this error on FlexPendant. Anything that I missed??
    Thanks.
  • soup
    soup ✭✭✭
    Not sure. Are you trying to this on a real or virtual controller?
    Until the robot arrives it will be on a virtual one. I do hope I can get it sorted when it does.
    Are you trying to say that there might be differences I need to know between the virtual and the real controller setup?
    Thanks for your time and help.
  • Baseframe calibration can be done in RS in the paths&Targets tab and the right click on the controller and select edit system
    Per Svensson
    Consat Engineering
