QStop event routine
ko414du4
Hello all,
Can I use QStop event routine to set a flag when a collision is detected? My system has a collision detection option but not multitask, so setting up a special task for this purpose is not an option.
Thank you for all the comments.
Hi, afcourse you can do this. When the robots stops, the event is executed, with your bool.
Jeroen5
