Sharing wobjdata in multimove
ko414du4
See "Relative Calibration" in the Multimove or FlexPendant manual.
Hi soup,soup said:See "Relative Calibration" in the Multimove or FlexPendant manual.
Thank you for your response. I have taken a look at "Relative Calibration" and tried it, but I got an error below. Anything that I missed??
Thanks again.0 -
Hi soup,
Is it possible that the error is because my system option is "604-2 Multimove Independent" as supposed to "604-1 Multimove Coordinated"? Thanks.0 -
Not sure. Are you trying to this on a real or virtual controller?
Until the robot arrives it will be on a virtual one. I do hope I can get it sorted when it does.soup said:Not sure. Are you trying to this on a real or virtual controller?
Are you trying to say that there might be differences I need to know between the virtual and the real controller setup?
Thanks for your time and help.0 -
Baseframe calibration can be done in RS in the paths&Targets tab and the right click on the controller and select edit systemPer Svensson
Consat Engineering0
