WPF of Winforms
I'm new in the forum. We are planning to desing a software to control the robots. All the documents are according to winforms. Is it possible to design our software in wpf and use all the libraries and commands like in winforms.
Is it worth to go with WPF? Or do you think that winforms is the easier way to go?
Regards
  • PerSvensson
    PerSvensson ✭✭✭
    I would go for WPF(newer technology that supports MVVM design pattern better) the only issue I can think of is if you have WinForm controls that you need to use but in that case WPF have WindowsFormsHost that solve it, at least it have done it for me so far.
    Per Svensson
    Consat Engineering
