Machine Tending 6.03 Trial License - Error
The trial license is invalid or does not work.
First Error: "MachineTendingPP: Failed to install trial license: Error in the application"
Second error: "Machine Tending 6.03: Failed to acquire license feature 'Machine_Tending_PowerPac_II'"
Looking at an similar issue I renamed the Trial_License folder to TrialLicense  - Then the first error goes away. However, the second error stays.
I tried to manually activate the license by pointing it to the "Bin" file. But, that procedure also throws an error.
Appreciate any help!
Regards,
Arun
  • Hello Arun,
    Are you using RobotStudio Trial license or Do you have the Full license ?
    If you are using the trial license and it has crossed 30 days, then PowerPac cannot be activated.
    thanks
    Sudarshan
