Profinet & LAN connection
With an IRC5 ( 6.0101) I am running into difficulties with the profinet and lan connection. The profinet connection has IP 192.168.122.2, and i want to give the WAN 192.168.122.3. However, the IRC comes up with a error as the 2 adresses overlap. Afcourse i do understand this problem, but how to fix this? I had the plan to use a EWON for remote support on the PLC and the controller, but that seems to be hard. Any ideas?
Thanks.
  • I have the same problem, and I want to do the same, use an EWON and the PC Interface.
    Un saludokind regards,
    Daniel Aguilar
    Automation Engineering
  • Please, UP. I have the same problem. LAN Address 192.168.250.123, and WAN 192.168.250.146
    Daniel Aguilar
