Array using flex pendant
Growl
Good morning all, I am (attempting) running some IRB 120's with (I believe IC5) flex pendant control.
I have had very little training but have managed to teach myself how to make joint, linear, circular moves along with gripper control, creating a user zero point and I'm pretty happy with program creation and generally running the system (my needs are few!) I am struggling to create an array, it's a little tough without any help to decipher the code!
In basic terms I have a pen (with some compliance) held in a gripper, I want to move to a zero point and then 'draw' a group of square boxes on a page in an array, the boxes are 40 x 40 and they are spaced at 20mm intervals with 2 colums and 4 rows (giving 8 boxes in total.
Is this possible to do just using the flex pendant? if how !!!!!!!!!!!!!!!...I'm sure i'll get there but it may jt
You can define an array using Flexpendant by click menus step by step as follows.
Main menu - Program Data - Select data types(for instance, num) - New... - Click Dimension - Select '2' - Click '...' - Change size of first 2, second 4 accordingly.And click 'OK' twice.
And then An array of numeric data is created. Refer to the picture below.
- 365 IRC5
- 84 OmniCore
