Conveyor tracking
Good Morning,
I am trying to build a station with two conveyors with robots that will load and offload on Robotstudio 5.06. I am doing this from stratch and desperately need all the help I can get.
Regards,
Unathi Kanda
Grip and release(event table) isn't supported in 5.06. You need to have 5.07 to do that.Per Svensson
Company Specialist
I have now finally installed Robotstudio 5.07 and on top of my conveyor tracking confusion, i cannot synchronize to vc. An unknown error is generated when I try.
I appreciate your help
BR
Unathi Kanda
Hi Unathi,
Do you have this problem with all your controllers, or only with one specific controller?
If it's one specific controller you have problem with, perform a cold start of that controller and try again.
Hi Anders,
Everything else seems fine. I've created paths and instructions and am trying to simulate the program. I need to synchronize to the virtual controller in order to setup my simulation but the unkown error is generated everytime I try.
See error message below
RobotStudio .NET exception dump
Base exception:
SYS_CTRL_E_UNRESOLVED_URL: The URL used to initialize the helper does not resolve to a valid object.
ERROR: .
apid.c[4697]: org_code: -30 new_code: 0xc0048416; RobRapidTaskImpl.cpp[246];
at RobApiWrapper.RobRapidTask.GetExecutionState(UInt32 cId, RobExecutionState& state)
at ABBInternal.Controller.RapidHelper.IsTaskExecuting(RsTask task)
at ABBInternal.Controller.RapidHelper.CheckAndLogTaskSyncPrecon ditions(String messagePrefix, RsTask task)
at ABBInternal.Controller.SyncToVC.ExcludeBadTasks(List`1 tasks)
at ABBInternal.Controller.SyncToVC.Sync()
at ABBInternal.Controller.SyncToVC.buttonOK_Click(Object sender, EventArgs e)Thank you for your help.
Unathi
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
