UDP Socket
Hello all,
I am currently trying to program a UDP socket on a IRB120 but somehow it is not possible to create the socket. Furthermore, the controller does not know the commands for UDP communication (SocketReceiveFrom or SocketSendTo). I already programmed a TCP connection and this one is working! but i have problems with the timedelay during receiving so i would like to try it with UDP!
Would be great if somebody would have an idea how to import the procedures for UDP-communication.
Thx in advance!
  • Micky
    Micky ✭✭✭
    Hello Matthias,
    maybe you are using an older RobotWare version, because the UDP communcation is available since Robotware 6.0
    BR
    Micky
  • Do you have the PCInterface option on the robot ?
    Regards
    Knud Erik Lindberg
    Danrobotics
