Does anyone have Smartgripper 1.04 package?
I am trying to reinstall robot system for our Yumi robot from a system backup, which has a robotware 6.01 and smartgripper 1.04.
I could only find the smartgripper 3.10 but the system suggests it is not compatible with the older version.
Does any one has the smartgripper 1.04 package ?
Thanks in advance!
Thanks in advance!
Hello Xiaoxing,
I have SmartGripper 1.04, here it isattached
Hope it works
Pablo1 -
Hello, I have a problem when I use "Go Offline" function to make a virtual controller fromthe Yumi robot. The error message is:Could not find a version of product distribution open.smartgripperv3 that is compatible with abb.robotics.robotware 6.03.01.00
I have installed Add-in SmartGrippper 3.20 and SmartGripper 3.30. Do you have any hints about it? Thank you!
Bests,
Ran0 -
Liberona said:Hello Xiaoxing,
Hope it works
Pablo
Finally I just followed the ABB suppliers' advice to update the robotware to 6.03 and smartgripper to 3.3 and it works good.
Anyway, thank you for your help !
rzhao said:Hello, I have a problem when I use "Go Offline" function to make a virtual controller fromthe Yumi robot. The error message is:Could not find a version of product distribution open.smartgripperv3 that is compatible with abb.robotics.robotware 6.03.01.00
Bests,
Ran
According to my experience, smartgripper 3.3 is compatible with 6.03. Maybe you should try reinstall this package again.
- 304 PowerPacs
- 354 IRC5
- 850 RAPID Programming
- 26 AppStudio
