Viewing Robot studio generated code
ssanford
Hello..
I'm very new to ABB and Robot Studio. I've been working through a getting started exercise by following a youtube video. At this point, my issue is that I can't seem to view the RAPID code in robot studio. I have clicked the RAPID tab but all I see here is a graphic View. I can click the program pointer and see the code but I don't think this is the proper spot to edit.. I know I'm doing (or not doing) something silly. Any help would be appreciated. Thanks.
Hi ssanford
When you click on the RAPID tab you can expand the controller tree (the RAPID code is inside the controller).
Inside you will find one or several tasks all written in RAPID code
/Oskar
Also, you can right-click an object in the Paths&Targets browser and select "Go to declaration". This will take you directly to the generated code.
Johannes Weiman
RobotStudio Team, ABB Robotics1
- 363 IRC5
- 80 OmniCore
- 853 RAPID Programming
- 31 AppStudio
