Hand-Eye calibration with end-effector
I am trying to calibrate an IRB with an integrated camera in its wrist - I am only concerned with the extrinsic parameters used to describe the camera's frame to the robot's frame and I really need this to be very precise and accurate.
What are the solutions out there?
Thanks.
  • Hi, i have similar problem.
    I need a tool to precise camera calibration. Do you have any idea what a toll I could use for this purpose?
    I will be grateful for information.
  • baijun
    baijun
    edited June 2017
    Thanks.
    Recently I saw this method, this method requires GPU, I have no way to test, you can try. If the effect is good please tell me.
    https://github.com/hengli/camodocal
