While Loop
Samucha
Hi' All
How to exit while loop and continue next command ?
Example
VAR num sum;
Example
VAR num sum;
PROC testwhile()
WHILE TRUE DO
Incr sum;
IF sum = 10 THEN
TPWrite "Sum :" \Num:= sum;
! ---------- Exit while loop and continue command
ENDIF
ENDWHILE
PROC summ()
testwhile;
TPWrite "Exit loop while";
Thanks for help.
PROC summ()
testwhile;
Thanks for help.
Hello
There is no break command but you could set a condition for the while loop like WHILE NOT sum = 10 THEN
/Pavel0 -
Something like this
VAR num sum;
VAR bool bExit:=FALSE;PROC testwhile()WHILE NOT bExit DOIncr sum;IF sum = 10 THEN
bExit:=TRUE;! ---------- Exit while loop and continue commandENDIFENDWHILEENDPROC
PROC summ()
testwhile;
ENDPROCPer Svensson
Consat Engineering0 -
Hi,All
Thanks for help.0
