Shortcuts disappear
I work with RS 6.03 and Arc Welding PP 6.02 and always when i've closed RS al shortcuts that i have defined are gone. The quick acces toolbar is also back to default settings when i restart a RS session. Does anyone known how to fix this?
  • Hello
    Do you mean shotcuts in the Quick tool access bar? Can you send a screenshot of the shortcuts you mean?
    /Pavel
  • Hi,
    Yes the shortcuts in the Quick tool access bar are gone
    But also shortcuts for example F2 that i use for Jump To
  • Hello
    The settings are saved in the file below. Any reason that RobotStudio is not allowed to save this file?
    %localappdata%\ABB Industrial IT\Robotics IT\RobotStudio\CommandCustomizations603.xml
    Are you on a school computer where they don't allow anything to be saved on the hdd?
    /Pavel
  • Hi Pavel
    No I’m on my work and I’ve al the rights to save there.
    In the file 'CommandCustomizations603.xml' I do not see the F2 Jump to command.
    I've tried to replace the xml file with a customized file with the F2 command in it but it won't work when I start-up RobotStudio and Arcwelding.
    It seems that shortcuts that i make in RobotStudio itself do not disappear only the shortcuts in Arcwelding are gone every time I start-up.
