Mastership is held by another client
C # program(PC-SDK) log on controller as default user , I guess it should be a FlexPendan also logged on to the controller, some people know the reason?
Not sure what the problem could be, some ideas:
- Is the robot in auto or manual mode?
- Also check the version of the PC SDK vs the Robotware version.
- Do you have another client with the mastership (e.g. RobotStudio) from the same or another computer?
If you move the key to auto and then to manual, the FlexPendant will request the mastership
Hope this helps !!
BR
Carlos Martinez
Hope this helps !!
BR
Thank you very much for your reply. Your comments are in place, giving me a great deal of inspiration.
The robot is in auto mode,and the version of PC-SDK is the same as that of Robotware(6.02).
Maybe RobotStudio is another client that hold Mastership.I have a question, if RobotStudio held Mastership, then PC-SDK how to write RAPID data?
Hi,carlosmtz2000
Proplem has been solved, it is true that robotstudio held Mastership.Your comments are in place, giving me a great deal of inspiration.
Thank you once again.
Not a problem
Carlos Martinez
ABB0
- 5.4K RobotStudio
- 385 UpFeed
- 15 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 285 IRC5
- 47 OmniCore
- 3 RobotStudio AR Viewer
- 748 RAPID Programming
- 15 Wizard Easy Programming
- 3 Job listings
