ABB SLP Distributor not installable for .NET Framework 4.6?
in UpFeed
Hello there!
I'm quite new to this Forum and not sure if this is the right place to put this, but here goes:
When I attempt to install the ABB SLP Distributor software on our server, which runs on
.NET Framework 4.6, I get the following error message:
Is it possible to get the SLP Distributor to work on the .NET Framework 4.6 or do we have to actually downgrade
the Framework on our server?
I really hope someone can help me out with this and thanks alot in advance
Hello
Which version of SLP is this?
/Pavel0 -
Hello
I found out only 3.5 SP1 works, but you can have multiple frameworks installed. So no need to downgrade, jsut installa 3.5.
/Pavel1 -
Hello Pavel
Thanks for the quick reply! the SLP version is: 3.2.1986.18
Alright I'll give that a go. Hopefully the two frameworks are not going to mess anything up
Cheers
Joona
Hello Joona
Were you able to install the SLP Distributor software then?
Because I'm facing the same problem here.
Thanks.0
- 858 RAPID Programming
