The problem of PC-SDK 5.15 in C# program.
Rainbow
Hello,Everybody;
My C# program can running with PC-SDK 6.03; Now I need this program running in PC-SDK 5.15.I change the "dll" with PC-SDK 5.15,When I running the program,it comes a problem in picture.
Can you give some advice about it.
Thanks very much.
I think you are missing a reference. Can you click on "View Detail" and show what is stated there?1
You should check the file: app.config1
Rainbow do you still need help on this?1
Thanks everybody,I had solved this problem by updating reference.0
彩虹,你是怎么解决这个问题的呢?能告诉我详细地说一下吗?我也遇到这个问题了,不过我的是使用 的最新版的PC-SDK和最新版的.NET4.5,示例程序是以前的来版本的,运行程序的时候就是你图中的那种错误。0
- 348 IRC5
- 845 RAPID Programming
- 21 AppStudio
