Get world frame limits?
Have you seen the Work Envelope feature?
We generate a MeshPart that you can see in green-yellow. It is rendered as TemporaryGraphics and attached to the mechanism. We do not have a public API for the work envelope generation unfortunately. I was looking into the code to see if it could be possible for you to access the MeshPart. From there you could check if a given point was inside the mesh or not. But.. it doesn't work
The required information is not accessible after the mesh has been generated and rendered.
Anyway most developers are iterating all points and check reachability with
<a href="http://developercenter.robotstudio.com:80/Index.aspx?DevCenter=RobotStudio&OpenDocument&Url=html/7a08590d-75ee-8eb7-c661-73136c31de7c.htm" target="_blank">CalculateInverseKinematicsAsync Method (RsTarget, RsToolData, Boolean)</a>
Can that work for you as well?
- 348 IRC5
- 845 RAPID Programming
- 21 AppStudio
