Problem in ScreenMaker
in ScreenMaker
Hello Users,
I did program in ScreenMaker, but i have a problem. In this moment is working one reference of a piece and everything is fine (The ScreenMaker Project was build with the reference working), but when i change the reference to a new piece ( I load a new module that corresponding to the new piece ) the ScreenMaker program gives an error (as in the picture). I think the error is associated with the loading of new variables, but these new variables are the same name as the old module. I think that i have associate the new variables to the ScreenMaker Project, how i do this in ScreenMaker?
Someone can help me?! Please.
the image says: Start display probem in flexpendant.
error creating object of type ABB.Robotics.SDK.Views.MainScreen
(TPSViewProducao.gtpu.dll)
The data for this message are not save in the event log of Robot Controller.
Hello, I have a similar problem, could you solve it?
Thanks in advance,
No, i could not solve the problem yet. I think that we have creat new variables in robotstudio and connect them to the variables in the program.
Someone can help us?
Thanks.0 -
- Do the new module have the same name? (so the reference to the RAPID variable remains the same?)
- Is the ScreenMaker app opened when the new module is loaded? If you re-open the ScreenMaker app after loading the file, do you still have the same problem?
BR
Carlos Martinez
- No, the new module have a different name. But the variables in each module remains with the same name.
- Yes, I already try re-open the screenMaker app after loading the file, but the problem remains.
- 348 IRC5
- 845 RAPID Programming
- 21 AppStudio
