RobotStudio "ABB Virtual RobotController" Crash
I've been working on the same virtual solution for a year, since RS6.01 and, once I have installed the RS6.04, the RobotController crashes as soon as I open the solution and it tries to connect to the robot controller. There it is the fault log.
I have 2 IRB4600 on the same solution with a quite big 3D model. The whole solution size is 320mb.
Any solution to this? I need to keep on working of this and I am not able to even open this system. Thanks.
Un saludokind regards,
Daniel Aguilar
Automation Engineering
  • Pavel Riabichev
    edited December 2016
    Hello
    Could you check if RobNetScanHost and RobComCtrlServer are running?
    If they are, try to kill them before starting your VCs.
    /Pavel
  • They are actually running both....
    Daniel Aguilar
  • Hello
    /Pavel
    Hi Pavel,
    I killed both before opening the VC and still crashes...
    Daniel Aguilar
  • Hello
    You should contact your local ABB and send a p&g of your station.
    /Pavel
  • I have fixed this through my local ABB, initializating the controller and doing an I-Start.
    Anyway, after few days of solving this, during the work on this station, a robotstudio Force Close happened, and it has corrupt the whole station! I cannot even open it.
    RobotStuido 6.04.01, the WORST robot studio that you have realeased... Full of bugs... I need to solve this.
    Daniel Aguilar
