IndDMove
Trying to use IndDMove on axis 6, like on one of my real robots,but i can not se the axis move in Robotstudio.
Code is like this
MoveJ pStart,v1000,fine,tCutRov;
IndDMove IRB,6,800,200;  (800Degrees at speed 200degrees)
MoveL pStop,v200,fine,tCutRov;
WaitTime 0.2;
I can not see that the axis is moving?(Yes ,i do reset the axis later in the code)
Robotstudio 2.0 Build 858
Ronny
  • Hello Ronny,
    In release notes you can read that RobotStudio doesn't support IndDMove:
    "Independent move is not supported
    The VirtualController does not support axes with independent movement"
    That means, just as you say, that you cannot see the movement.
    Best regards
    /Ulrika Mor?n
    Support Engineer
