Cannot sync Rob Targets to RAPID
c63amg
I created targets and path in PaintPowerPac...
Everything appears in the home tab like I expect...
yet when I got to sync to the RAPID, my targets do not get transferred over...?
My path, tool data, work obj constants, all get sync'd over like expected, but the actual rob target data does not.
any ideas? Is it a paint power pac issue?
Usually these options are drop downs, with the targets inside...
This is a bug that's been there for a couple of years:
https://forums.robotstudio.com/discussion/9383/sync-to-vc-bug
The only way to reliable sync to VC is one routine at a time, which can be very frustrating when you have up 10 routines to sync.....
- 365 IRC5
- 84 OmniCore
