Creating points from RobotStudio
Rafał
I was wondering if there is a possibility to create points in online mode not from FlexPendant but from RobotStudio?
I was looking for some options, for example Online Monitor, but there it is no way to check real robot position.
Have you got a station for this robot in RobotStudio? What I normally do is create a station first, define my targets from the station and synchronise it with VirtualController. Final step, copy the data from VirtualController to the real controller via online connection.0
Well I don't have a station, but I need high accuracy, so there is no way to create targets from the VirtualControler. I was looking for something like to check what is my real robot position, but from the RobotStudio, not via FlexPendant.0
Rafał said:Well I don't have a station, but I need high accuracy, so there is no way to create targets from the VirtualControler. I was looking for something like to check what is my real robot position, but from the RobotStudio, not via FlexPendant.0
- 350 IRC5
- 848 RAPID Programming
- 22 AppStudio
