auto path failed??
                    Klaus
                    When i try to make an autopath from curve i get this error:
                Auto Path Failed: Make sure the correct motion type (Linear or Circular) is selected in the active Instruction Template	21-11-2012 13:43:13	General
Where do i set motiontype in active instruction template
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
Klaus Soenderhegn
www.cadalysator.dk
You can select the motion type from the status bar,
            Have the same problem. Could you please re submit the photo where I can find motion type option ?0
Found it. No need for a picture anymore.
 - 363 IRC5
 - 81 OmniCore
 - 853 RAPID Programming
 - 31 AppStudio
