Auto acknowledge input
Ricki
Br:Rickard
Can anyone explain
the Auto acknowledge input option that is find under Engineering Tool in Installation
Manager.
I did check the box while I was creating a new system but I can´t find out what
changes it makes to the system.
Br:Rickard
It's an option which allows the normally manual process of acknowledging that the system was switched into Auto on the pendant to be preformed by a signal. Example of use: The signal could be used by a safety-rated PLC to acknowledge Auto mode via logic over requiring a human to push the acknowledge on the pendant.
