RECORD access via PC-SDK
Hi all,
I have an array of RECORD like below. How can I access it with struct in PC-SDK?
RECORD rec
    num myNum;
    pos myPos;
ENDRECORD
PERS rec myArray{2}:=[ [ 2, [ 1, 2, 3 ] ], [ 3,[ 4, 5, 6 ] ] ];
Thanks for the help.
Best Answers
  • ko414du4
    ko414du4
    Answer ✓
    Hereby a sample program. If you have any questions about it, just let me know :smile:
    Thank you very much for this John_Verheij. Works like magic!
    I also took it further by making the structure implement IRapidData like below. This allows the variable to have more or less the same function as the other RapidDomain structures.
    In this sample, rec RECORD is defined in RS as follows:
    RECORD rec
            num num1;
            robtarget tgt;
    ENDRECORD
    public struct Rec : IRapidData
        // Structure fields
        private Num num;
        private RobTarget tgt;
        private RapidData refRapidData;
        // Structure properties
        public Num NumVal
            get { return num; }
            set { num = value; }
        public RobTarget TgtVal
            get { return tgt; }
            set { tgt = value; }
        public static Rec Empty
            get;
        public Rec(RapidData input)
            UserDefined ud = (UserDefined)input.Value;
            // Initialise struct fields from the RapidData:
            // ~ refRapidData takes the REFERENCE of the RapidData. This is useful in SaveToRapidData() method.
            // ~ num & tgt takes the VALUE of the RapidData components. This is useful in making internal temporary
            //   changes before saving it (back) to the RapidData by SaveToRapidData() method.
            this.num = (Num)ud.Components[0];
            this.tgt = (RobTarget)ud.Components[1];
            refRapidData = input;
        public override string ToString()
            return "[" + NumVal + "," + TgtVal + "]";
        public void SaveToRapidData()
            // c is the controller defined globally. Required to request mastership.
            using (Mastership ms = Mastership.Request(c.Rapid))
                refRapidData.StringValue = this.ToString();
        public void Fill(string value)
            char[] delimiterChars = { ' ', ',', '[', ']' }; // Get rid of these chars from the value input
            string[] tokens = value.Split(delimiterChars, StringSplitOptions.RemoveEmptyEntries);
            // Assign struct's fields: NumVal
            NumVal = new Num(Convert.ToDouble(tokens[0]));
            // Assign struct's fields: TgtVal
            RobTarget newTgt = new RobTarget();
            newTgt.Trans.X = Convert.ToSingle(tokens[1]);
            newTgt.Trans.Y = Convert.ToSingle(tokens[2]);
            newTgt.Trans.Z = Convert.ToSingle(tokens[3]);
            newTgt.Rot.Q1 = Convert.ToSingle(tokens[4]);
            newTgt.Rot.Q2 = Convert.ToSingle(tokens[5]);
            newTgt.Rot.Q3 = Convert.ToSingle(tokens[6]);
            newTgt.Rot.Q4 = Convert.ToSingle(tokens[7]);
            newTgt.Robconf.Cf1 = Convert.ToInt32(tokens[7]);
            newTgt.Robconf.Cf4 = Convert.ToInt32(tokens[8]);
            newTgt.Robconf.Cf6 = Convert.ToInt32(tokens[9]);
            newTgt.Robconf.Cfx = Convert.ToInt32(tokens[10]);
            newTgt.Extax.Eax_a = Convert.ToSingle(tokens[11]);
            newTgt.Extax.Eax_b = Convert.ToSingle(tokens[12]);
            newTgt.Extax.Eax_c = Convert.ToSingle(tokens[13]);
            newTgt.Extax.Eax_d = Convert.ToSingle(tokens[14]);
            newTgt.Extax.Eax_e = Convert.ToSingle(tokens[15]);
            newTgt.Extax.Eax_f = Convert.ToSingle(tokens[16]);
            TgtVal = newTgt;
        public void Fill(DataNode root)
            throw new NotImplementedException();
        public void FillFromString(string newValue)
            Fill(newValue);
        public DataNode ToStructure()
  • Hi,
    Thanks, John_Verheij!! I will give this a go and let you know how it  goes.
