Acquiring Force with PC SDK
BorjaB
Hi All,
I have a question about how to acquire the force data trough PC SDK. Actually, I have performed a small application with Visual Basic for acquiring the position of the TCP, but now I also want to acquire the force that the robot is performing in every position. The problem I found is due to I didnt find any instruction in the PC SDK for acquiring force data. I know that it's possible because the Test Signal viewer is doing the same but only for acquiring force.
Can any body help me?
Finally it's done, If anyone wants to know how to perform it let me know and I will help.
Regards,0 -
Hi! Could You tell me how did you manage to do it?
Best regards
Wojtek0
