6.06 new paint visualizer | smart component
c63amg
Is there more information somewhere about setting up the smart components for the new spray visualization?
Yes a tutorial would be good on this.
Got it.
- Create your smart component.
- Add the three components
- create an i/o signal for that smart component. this will receive the signal from the controller
- add connections between components (I used the design tab)
- Then the key is to go into simulation tab > station logic > design tab > select the drop down from your controller > select A1brush > then make a connection between that unit, and your new spray simulator
the next thing I am trying to figure out is how to simulate with multiple parts.
The PaintApplicator component will only accept 1 part.
I guess you could either
1) Use one Applicator component for each part,
2) Update the Part property as the robot moves to a new part, or
3) Merge the parts into a single part.
Johannes Weiman
JWeiman said:I guess you could either
I tried 1, it produced some funky results.I think 2 would be the best route in my case, but I haven't figured it out yet.
3 is difficult in my situation unfortunately.
Bonjour à vous
merci pour tes explications C63amg vraiment bien ton post,par contre j ai bien fait toutes les étapes que tu décris mais quand je lance ma simulation ça ne peint pas les pièces , pourrais tu m aider??
Neily03 j ai vu ta vidéo sur YouTube tube j aimerais vraiment arrivé à ce résultat c vraiment bien ...
j espère que vous pourrais m aider.
d avance merci,
c63amg said:JWeiman said:I guess you could either
There is a bug with using multiple applicators that will be addressed in 6.07. (They would unintentionally share the same texture.)
Johannes
Johannes Weiman
- 365 IRC5
- 84 OmniCore
