How to program the self-created robot?
                    jerry-licao
                    Hello everybody:
I want to create a robot from the tab :modeling-create mechanism-Create robot. when I finished, I can jog the robot,but how can I program it? Thanks
            Hi Jerry,
Sounds like you're re-inventing the wheel my friend. However, I think you can do this via Smart Components. Having said this, it's only going to be signals that makes the mechanism/robot to move. If you are so eager to program the way ABB do it for their robots, you might then want to have a look at the PC SDK or RobotStudio SDK. But again, I think it's going to be super complicated, if not impossible. Plus, it's re-inventing the wheel..
            ko414du4 said:Hi Jerry,
hello ko414du4:
Thanks very much for your suggestion ,I could do it via the smart component and the robot can run from one position to another ,but can not move linerly like ABB robot .what i want is to program it like ABB standard robot, using MoveL/MoveJ instruction .
Maybe I will study the SDK for some information ,Thanks .0 -
What you need is Stand Alone controller here is manual:
Create mechanism, create a system with a stand alone controller where you define what kinematic model you have created(very important), modify MOC.cfg according to your model so the controller knows whar robot/machine it is.
/Adnan
/Adnan
Oh Thanks very much...You showed me a way.0
 - 363 IRC5
 - 81 OmniCore
 - 853 RAPID Programming
 - 31 AppStudio
