RMQ settings when set up task
Can someone explain the differences between RMQ mode (internal/remote) and also RMQ type (interrupt/synchronous) please?
I saw the RMQ options when setting up tasks and was wondering what are the settings for/when to use them.
Thank you !
RMQ is when you use a SDK for controlling the robot. In that way you can specify where the messages are coming from.
Hope this helps.0
