meaning of codes
Hello all !
I working with robot IRB2600ID and i start science with robotstudio.
I do not understand the meaning of many codes. Do you have any list of codes?
For example:
bEscludiLaser:=false;
SetDO Pb_O17_ControlCodeDone,1;
For example:
PDispOff;
ResetTuneRobot;
CollisionHandling;
Someone is from Poland ?
Thanks for help
CollisionHandling;
Thanks for help
RobotStudio comes with a RAPID instruction reference manual where all the instructions are described, check the Help section. You can alternatively put the cursor at the instruction in the RAPID editor and press the F1 button to bring up the relevant help section.Henrik Berlin
Do you have a online instruction ??? When i come back to work i check help section.0
