Suggestion: Jog in Freehand puts selection to "Mechanism Selection"
I'm not sure how that would work. For Joint jog you have to select the link to jog, and the links consist of parts. Linear/Reorient jog work the same whether the mechanism or any part in it is selected.
I agree that freehand rotation needs improvement; it should always rotate around the local origin;
Regards,
Johannes
Johannes Weiman
That is very true, i was mostly thinking about Linear/Reorient jog to auto set to "Mechanism Selection", jog Joint, as you say, need "Part selection" to work.
/Erik0
- 341 IRC5
- 68 OmniCore
- 839 RAPID Programming
- 18 AppStudio
