Help: Motor ON, Main Start... from external signal!
Hi everyone!
Instead of pushing the button on IRC5 controller, I want to set up an other button outside of controller to activate some system events like: Motor ON, Main start (PP to main),.. by external signals. But i still haven't found how to do this yet. I believe that there must be methods to do this.
So please  give me some advices on this if you know!
Thank you so much in advance!
  • i've already found the solution :D
  • Hello linh_le_vn!
    Could you please share how you did that, if possible?
    Thank you in advance
  •  Dear Sir,
    Please share how you did that?
  • You have to configure a system input, under Robotstudio-> I/O System -> System input, you add a system input, "Motors on and Start" and tie it to a digital signal.  Alternatively you can edit the EIO.CFG file
    SYSSIG_IN:
          -Signal "externalsignalname" -Action "MotOnStart"
