6.06 new paint visualizer | smart component
                    c63amg
Is there more information somewhere about setting up the smart components for the new spray visualization?
            Yes a tutorial would be good on this.
            Got it.
- Create your smart component.
 - Add the three components
 - create an i/o signal for that smart component.  this will receive the signal from the controller
 - add connections between components (I used the design tab)
 - Then the key is to go into simulation tab > station logic > design tab > select the drop down from your controller > select A1brush > then make a connection between that unit, and your new spray simulator
            the next thing I am trying to figure out is how to simulate with multiple parts.
The PaintApplicator component will only accept 1 part.
            I guess you could either
1) Use one Applicator component for each part,
2) Update the Part property as the robot moves to a new part, or
3) Merge the parts into a single part.
Johannes Weiman
            JWeiman said:I guess you could either
I tried 1, it produced some funky results.I think 2 would be the best route in my case, but I haven't figured it out yet.
3 is difficult in my situation unfortunately.
            Bonjour à vous
merci pour tes explications C63amg vraiment bien ton post,par contre j ai bien fait toutes les étapes que tu décris mais quand je lance ma simulation ça ne peint pas les pièces , pourrais tu m aider??
Neily03 j ai vu ta vidéo sur YouTube tube j aimerais vraiment arrivé à ce résultat c vraiment bien ...
j espère que vous pourrais m aider.
d avance merci,
            c63amg said:JWeiman said:I guess you could either
There is a bug with using multiple applicators that will be addressed in 6.07. (They would unintentionally share the same texture.)
Johannes
Johannes Weiman
 - 363 IRC5
 - 81 OmniCore
 - 853 RAPID Programming
 - 31 AppStudio
