Help: Motor ON, Main Start... from external signal!
Hi everyone!
Instead of pushing the button on IRC5 controller, I want to set up an other button outside of controller to activate some system events like: Motor ON, Main start (PP to main),.. by external signals. But i still haven't found how to do this yet. I believe that there must be methods to do this.
So please give me some advices on this if you know!
Thank you so much in advance!
-1
i've already found the solution
-1 -
Hello linh_le_vn!
Could you please share how you did that, if possible?
Thank you in advance0 -
Dear Sir,
Please share how you did that?
You have to configure a system input, under Robotstudio-> I/O System -> System input, you add a system input, "Motors on and Start" and tie it to a digital signal. Alternatively you can edit the EIO.CFG file
# SYSSIG_IN: -Signal "externalsignalname" -Action "MotOnStart"1
- 365 IRC5
- 84 OmniCore
